It is currently Thu Nov 12, 2026 1:47 am
PostPosted: Wed Oct 08, 2008 6:11 pm
Ive been reading the how -to on the HEI install, and it says to connect the wires of the ballast resistor together. Will this also work with a dual ballast?
I know that one side has different resistance than the other, and didnt know if had to be wired differently. BTW, this is on a '79 B-100. Also I have installed a Blaster 2 coil, and all the recommended tune up parts I've learned about from the gurus on this site. Also, the coil I got came with a ballast resistor, but it's only a single. What would I do in this situation to use the ballast that came with my coil? I have 2 Green wires together on the upper right terminal, a Pink wire on the upper left terminal, and a Red wire on each of the bottom terminals. Any ideas??? :shock:
"MOPAR or NOCAR!"
PostPosted: Thu Oct 09, 2008 11:44 pm
I have the same situation (dual ballast) and will be interested in the responses to this.
________
arizona dispensaries
PostPosted: Fri Oct 10, 2008 7:23 am
You'll be fine to just proceed the same way as if you had the single ballast resistor: Unplug both connectors from the dual ballast and connect them to each other. It's just that you'll need two jumper wires rather than one. You can use 1/4" strips of brass or make up jumper wires from short lengths of #14 wire with 1/4" male spade terminals on each end.
PostPosted: Fri Oct 10, 2008 2:32 pm
:lol: Thanks for the reply Dan! You are a wealth of information!
"MOPAR or NOCAR!"
