It is currently Fri Nov 20, 2026 8:09 pm
PostPosted: Fri Oct 10, 2008 12:55 pm
Has anyone noticed from my pics that my front wheels stick out more than my rear wheels? I had to put 1/8" spacers in the fromt because I kept snapping lug nuts, could that be the problem? My tires are 205/75R14 in the front and 195/75R14s in the rear (it was like that when I got it). Both rims are 14x6.
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Fri Oct 10, 2008 1:08 pm
Front track on these cars is wider than the rear. It's normal. Snapping wheels studs is not normal and should be investigated. A spacer should not be needed to cure the wheel stud breakage.
PostPosted: Fri Oct 10, 2008 1:19 pm
You were snapping the nuts? Or the studs? These studs break off pretty easily... what torque were you putting them on at? They only require ~50 ft. lbs. Anymore than that and they have a habit of snapping. I broke 3 in a row doing that before I figured out what it was.
I would think a spacer would actually make the problem worse, the torque on the stud is farther out, so there is more stress on it.... interesting.
~THOR~
PostPosted: Fri Oct 10, 2008 1:21 pm
It wasn't the studs, it was the lug nuts. The cragars were too close to the drums on the front and one of the nuts (usually the last one) would bind and snap the "shank" or what ever its called off. The wheel spacers solved that problem. The nuts would snap at 50 to 55 ft lbs.
PostPosted: Fri Oct 10, 2008 1:23 pm
I see why now. The shanks are too long without the spacer on the front. Are your wheels aluminum? The only time I've ever seen the need for shanked lug nuts is with something like slot mags, where there is no bevel on the lug holes of the wheels. Can't you use standard lug nuts?
~THOR~
PostPosted: Fri Oct 10, 2008 1:29 pm
~THOR~
Im not sure if Cragar SSs are aluminum or not. The studs don't even stick out when you put the rims on, so I can't use regular lug nuts. I had to special order the new lug nuts from Cragar.
PostPosted: Fri Oct 10, 2008 1:36 pm
The spacers shouldn't be a problem... unless a wheel flies off around a hard cornering maneuver, then I would leave it alone...unless you want to install longer studs, which are available.
~THOR~
PostPosted: Fri Oct 10, 2008 1:41 pm
:shock: I hope not! Im gonna stick with the cheaper, leave the spacers. :D Now I can tell people the front/rear wheel problem is actually normal. 8)
PostPosted: Fri Oct 10, 2008 2:21 pm
Ahh, you had lug nuts that were too long. You can get different lengths so I would find shorter ones and ditch the spacer.
PostPosted: Fri Oct 10, 2008 2:50 pm
We tried, the spacer was my grandpas idea though.
PostPosted: Fri Oct 10, 2008 4:05 pm
A 1/8" spacer won't hurt anything.
We used to have a Camaro that had stock spacers (forgot front or rear) that were about 1/8" thick.
 Post subject: tires
PostPosted: Fri Oct 10, 2008 4:12 pm
just a thought-- why not put the smaller tires on the front? the wheels are the same -- just different tire sizes? Lawrence
 Post subject: Re: tires
PostPosted: Fri Oct 10, 2008 5:29 pm
Im probably going to have to do that anyway, because the front tires scrape sometimes. I was more concerned about the front tires sticking out more than the rear.
