It is currently Mon Nov 16, 2026 4:08 am
 Post subject: supercharged slant
PostPosted: Fri Oct 10, 2008 2:59 pm
hey i am building a supercharged slant is but i have one question about pistions what pistons should i use becouse a while back on here i read bout a turbo slant and all his pistons ended up in his oil pan so i want to avoid that and i am gonna go about 8-9 psi of boost and also what else should i know about superchargers
thanks
josh
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Fri Oct 10, 2008 4:50 pm
Stock pistons will work fine if you keep the afr correct.
PostPosted: Fri Oct 10, 2008 5:01 pm
well i am gonna have to bore it some couse it smokes
Whats the afr
PostPosted: Fri Oct 10, 2008 6:32 pm
Air fuel ratio = AFR
PostPosted: Sun Oct 12, 2008 8:06 am
200,000 mile stock pistons + hone,re-ring,re-bearing + 10LBS of boost + CORRECT AFR = no problems.
PostPosted: Tue Oct 14, 2008 8:07 pm
What afr Should one Shoot for under boost? 14.7? 13? 12?
Thanks, Greg
PostPosted: Wed Oct 15, 2008 5:12 am
Around 11.5:1 under boost conditions.
PostPosted: Wed Oct 15, 2008 2:39 pm
I think from reading this thread, pistons are the least of your worries. :shock:
PostPosted: Thu Oct 16, 2008 11:55 am
I tend to run 10.5 or as rich as possible under boost without sacrificing power. the rich mixture cools the air charge and pistons. my luck has been if its not as rich as possible than just the wrong conditions cause lean afr and pistons go by by. but maybe thats just my luck? or that every other motor I've blown hasn't been a /6. they do seem to take allot more abuse than anything else
Nick
86 d150 turbo /6.
