It is currently Fri Nov 13, 2026 9:12 pm
 Post subject: engine build
PostPosted: Mon Oct 13, 2008 2:47 pm
ok i need some help im building a slant six and trying to get my budget together and i want some imput of am i missing anything major the head work is not included and like bearings and other stuff
COMP Cams lifters
COMP Cams valve springs
COMP Cams timeing gears
COMP Cams 264s
PerTronix Flame-Thrower II Ignition Coils
Federal Mogul Z244NP60 .60 over pistons
ignitor 2 electric ignition
flex fan
thanks josh
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Mon Oct 13, 2008 3:10 pm
Last edited by Aggressive Ted on Mon Oct 13, 2008 6:21 pm, edited 1 time in total.
 Post subject: erson cam,
PostPosted: Mon Oct 13, 2008 3:15 pm
i think that the erson Group cam buy will save you money and be better than the comp cams offer, search " erson cam" on this forum....
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Mon Oct 13, 2008 3:17 pm
I'd add ARP rod bolts and main studs for insurance, which will (probably) require an align hone on the main caps.
vm
PostPosted: Mon Oct 13, 2008 3:44 pm
well i want the comp cam for milage reasons and i dont know much about erson camd
PostPosted: Mon Oct 13, 2008 4:19 pm
What kind of mileage are you thinking the Comp cam will produce? Are you running a 1bbl or 2bbl carb? Anybody have any input on mileage figures from the Erson cam? Thanks for any info.
PostPosted: Mon Oct 13, 2008 4:32 pm
ive herd the comp gets good milage and i am running a 4bbl but i wont dog it all the time (keep it on the primarys)
PostPosted: Mon Oct 13, 2008 4:38 pm
I am getting a little over 20 MPG with an Erson 260 / 244 RDP grind and a Carter BBS 1 bbl carb.
PostPosted: Mon Oct 13, 2008 5:42 pm
I am running a comp 252 in my daily driver and am getting 18+ mpg in stop and go city driving. Otherwise I am not thrilled with its performance and the rocker clatter is fairly pronounced even with scary tight lash tolerances. :shock:
I would be happier with virtually any other cam (even stock!)
. . . there was good sport at his making.
