It is currently Mon Jun 22, 2026 5:31 am
 Post subject: Turn Signals
PostPosted: Fri Oct 17, 2008 8:55 pm
I my way home from work tonight, my turn signals broke, :( but in a wierd way. They are solid now and do not even blink. They worked about 2 mi up the road from my house, and now they don't. No light is out, just when I turn the turn signals on, its just a solid green arrow and solid lights on the out side. None of them even blink! :shock:
Please healp!
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Fri Oct 17, 2008 9:01 pm
Replace the turn signal flasher.
PostPosted: Fri Oct 17, 2008 9:06 pm
Wow, it went out just like that?
Whats a good replacement? And, forgive my stupidity, where it it located? Is it that round silver thing under the dash?
PostPosted: Sat Oct 18, 2008 12:25 am
If you found the round silver thing, then there it is. Do the hazards work?
Do as Dan says (sounds like a T.V. show doesn't it?) and replace it. I suggest getting an electronic one from your friendly parts store. They are about 5-6 bucks on average, and will draw alot less current than the old Bi-metal units. Plus... you get that new car "clicking" sound.
W00t..
~THOR~
PostPosted: Sat Oct 18, 2008 4:21 am
Thanks guys! :D I will go an get one today.
PostPosted: Sat Oct 18, 2008 6:59 am
Yep, electronic. Ideal or Tridon #EL-12C. It's in a see-through plastic can instead of metal.
PostPosted: Sat Oct 18, 2008 2:21 pm
Thanks a lot guys! :D
PostPosted: Sat Oct 18, 2008 3:35 pm
I just got my new flasher, still no signals! :( My emergency flashers work, but not the turn signals. Any suggestions? Is there a fuse?
PostPosted: Sat Oct 18, 2008 6:04 pm
There should be 2 flashers. One for the emergency and one for the turn lights
Mike
An officialis Tyrde-Browne Racing membrum
PostPosted: Sat Oct 18, 2008 7:14 pm
Oh... I guess I found the emergencys then! :oops: Where might the turn lights flasher be?
PostPosted: Sat Oct 18, 2008 7:24 pm
Well, mine is under the dash close to the glove box, kinda between the heater controls and the glove box itself. This is in a '68 Dart.
Mike
PostPosted: Sat Oct 18, 2008 7:32 pm
I will go out and check this right now!
PostPosted: Sat Oct 18, 2008 7:35 pm
Good luck!! White cars RULE!!!
PostPosted: Sat Oct 18, 2008 7:50 pm
Thanks, and hell yea!
It worked!!! You are a genious! Thanks a lot! I have turn signals now!!!
PostPosted: Sat Oct 18, 2008 7:53 pm
No problem, Glad I could help.
Mike
