It is currently Tue May 19, 2026 1:58 am
PostPosted: Sun Oct 19, 2008 10:42 am
I found another trans for $35 I want to get, but its out of a 70 cornet wagon. Will that work?
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Sun Oct 19, 2008 11:35 am
What engine is in this '70 Coronet wagon?
PostPosted: Sun Oct 19, 2008 11:46 am
Its a Slant 6 :D
PostPosted: Sun Oct 19, 2008 11:50 am
In that case, yeah, it'd fit and work.
PostPosted: Sun Oct 19, 2008 1:34 pm
Ok, Im going to get it just in case then! Thanks! :D
PostPosted: Wed Oct 22, 2008 9:20 am
While you're at it, may I suggest you look *very* closely at the cooling lines for leaks? I've twice found very small leaks that caused problems with shifting (maybe air got sucked in?), but didn't really leak significant amounts of fluid.
PostPosted: Wed Oct 22, 2008 2:08 pm
The trans was out of the car when I found it. It supposedly only has 77,000 mi on it, but that could be 177,000. Im only going to get it for a rebuild if the adjustments don't work out on my current one.
