It is currently Tue Nov 10, 2026 8:55 pm
 Post subject: Boiling Battery
PostPosted: Mon Oct 20, 2008 3:32 pm
Car Model: 1986 D100 /6 A833od shortbox
My battery on my '86 Ram started boiling today. I noticed a sulfurous smell in my drive home tonight, getting worse and worse. Got home, and the battery was whistling. Yesterday, the battery died in the driveway, and I recharged it easily. Bought the truck in Jan this year, and swapped the battery out with my '92 Dakota. The battery is a 4 year old Diehard. What might be the problem? I plan to check the volt at the terminals to make sure the system isn't overcharging, but thought that maybe the age played a role in its boiling. thanks
PostPosted: Mon Oct 20, 2008 3:57 pm
The battery ought never to boil at any age; small bubbles can form under heavy charging, but boiling is very, very bad and could be due overcharging or shorted cells allowing way too much voltage on the unshorted cells. I wouldn't drive it until I checked it out, and be very careful - a friend had the whole top of the battery blow off in his face when he went to check it after encountering a similar problem. Only his glasses saved his eyes from serious injury.
 Post subject: voltage
PostPosted: Tue Oct 21, 2008 7:49 am
my voltage regulator failed causing this ... It was " stuck" putting out 14.4 ALL the Time and my battery was spitting up water, making a mess. Check voltage with a multimeter.
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Tue Oct 21, 2008 2:03 pm
My voltage reg went bad and was putting full charge all the time into the batt! Im glad it didn't blow up! :D I have had this happen on two seperate occations. :roll:
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
