It is currently Wed Nov 18, 2026 6:22 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Wed Oct 22, 2008 5:09 am
Does anyone have a bronse oil pump gear like the v8s use in high performance applications? v8s have the same problem untill they switch
Nick
86 d150 turbo /6.
PostPosted: Wed Oct 22, 2008 6:20 am
If I'm not mistaken, the V-8's only use the bronze gear, if they are running a steel roller cam.
PostPosted: Wed Oct 22, 2008 11:53 am
I have case hardened SL6 oil pump gears and gears made from a special nickel - bronze alloy. As noted, the bronze gear is designed to be used with steel cams.
