It is currently Tue Nov 17, 2026 9:49 pm
 Post subject: exhaust leak!
PostPosted: Fri Oct 24, 2008 9:51 am
i just put a 2 barrel carb and intake manifold on my 1970 valiant /6 and i can hear a big exhaust leak i think its coming from between the intake manifold and exhaust manifold.
any suggestions?
225 Slant Six [Super Six]
PostPosted: Fri Oct 24, 2008 10:12 am
It is very much worth your while to get the good gaskets for the manifolds-to-head and intake-to-exhaust junctions. The sheetmetal intake-to-exhaust gasket almost never seals well.
PostPosted: Fri Oct 24, 2008 2:11 pm
Have you read This Article??
PostPosted: Fri Oct 24, 2008 2:22 pm
Remflex.com makes an excellent gasket for this joint.
PostPosted: Sat Oct 25, 2008 5:33 am
Aspirator air system: you may find to the rear of your manifolds an extra hole left unplugged, it took me months to find this agravating leak!
Remflex is the way to go on gaskets, they dont make a gasket for the exhaust pipe itself but send a nice bicuit of their material for you to play with,just overlay your gasket on this buscuit cut out the center,works perfect!
robert
PostPosted: Sat Oct 25, 2008 7:20 am
There's no hole in either manifold related to the secondary air injection or aspirator system; that hole is at the rear of certain 1972-up cylinder heads. Some late-production exhaust manifolds have a threaded hole on the rear wall of the central collector for an oxygen sensor.
Remflex is one of two equally-good ways to go on the gasket, if we're considering only the quality of the gaskets and the speed with which they're delivered. Ted provided the Remflex link, and I provided the other.
If we also consider vendor support of the slant-6 community, the GPRS (Australian) gasket wins bigtime, because of the MLS head gaskets they're making for us — right now in a version for the iron block, and soon in a version for the aluminum, too.
Users browsing this forum: Bing [Bot] and 6 guests
