It is currently Wed Nov 11, 2026 10:43 pm
PostPosted: Fri Oct 24, 2008 9:15 pm
73 Dart with stock electronic ignition.
Driving home from Los Angles, about 100 miles the car ran fine for 50 miles until I stopped in traffic. Car died, no spark. Towed car off freeway, doubled checked all connections I could find. Everything seemed tight and the car would still not start.
Walked a mile to the parts store, got test light. Got power at ballast resister, coil and every other place that I could think of to look. Tried starting it again and it fired to life about 2 hours after it originally died. Drove home, car ran fine. Has worked fine for the last two days.
I have doubled checked everything. Can't find anything wrong.
Any ideas?
PostPosted: Sat Oct 25, 2008 7:30 am
Heat-induced failure of one of your ignition components. Control module, distributor pickup coil, or ignition coil. Works fine when it's cold, starts to fail when it heats up.
PostPosted: Sat Oct 25, 2008 6:58 pm
Another possibility: Rust and dirt in the fuel can temporarily clog the fuel filter, then fall off after a rest and allow a restart.
 Post subject: bulkhead
PostPosted: Sat Oct 25, 2008 7:44 pm
firewall bulkhead connector bad contacts, heat soak as it was hot as crap this week, the ghost of mopar wiring, dirt or rust in the gas tank
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Sun Oct 26, 2008 2:49 pm
not as long as there's no spark.
throw away your testlight and buy a multimeter. keep it on the seat so that when your ignition system fails you can properly test the components. a test light will not allow you to do that.
you not only want to verify power, you also need to verify ground, continuity and resistance of the components.
