It is currently Tue Nov 17, 2026 5:47 am
 Post subject: carter bbd vs. weber
PostPosted: Sun Oct 26, 2008 6:46 pm
I need to get a new carburetor and i was wondering if it would be better to get a weber (not sure which one) or get another bbd? I would like to hear everyones opinion on this. Also would the weber get better acceleration or mpg than the bbd?
Setup: 225w/super six conversion
 Post subject: progressive
PostPosted: Sun Oct 26, 2008 6:59 pm
the Weber will outperform the BBD generally, better response and MPG. If they were not so pricey i'd like one on my super six too.I like my BBD but a progressive Weber would be better (IMHO)
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Sun Oct 26, 2008 7:02 pm
thats what i was thinking about it being progressive. what do you think about the model weber to use.
PostPosted: Sun Oct 26, 2008 8:15 pm
i was looking around and it seems like the 38 DGES might be a good choice.
PostPosted: Sun Oct 26, 2008 8:36 pm
I love my BBD! gets around 20 mpg city in my Duster. A lot better than my 1920. Ive never even seen a weber on a SS set up though.
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Mon Oct 27, 2008 12:19 am
Oh, I dunno...
I did like the 38-38 dgas on a super six intake, but it was a lot of tinkering to hook it up the linkage.
The bbd fits as is
Both of them work, but I used the weber because it was easyer to find over here than a bbd in good shape.
The webers are more work to get to work just right, with all kinds of jets and stuff.
I guess I would go for the weber if you have lots of time to learn how they work, and set it up.
But the bbd works well, and is "easy" :? :?
PostPosted: Mon Oct 27, 2008 7:46 am
Here's Joshua Skinner's ARTICLE on assorted carburetor options.
PostPosted: Mon Oct 27, 2008 9:59 am
Im running the 32/36 DGEV[?] in my van, I like it alot! The hardest thing was getting it dailed in with jets, I can dail the idle down to 200 RPM but as soon as I put it in drive it conks out which is self explainatory. I spent about 250 for it.
PostPosted: Mon Oct 27, 2008 10:25 am
What rear gear ratio are you running?
What type of mileage do you get on trips?
vs around town?
PostPosted: Mon Oct 27, 2008 1:48 pm
Did you get the weber new? If so, where at?
PostPosted: Mon Oct 27, 2008 7:07 pm
no i dont have the weber yet. and for the previous post im getting about 17mpg . i drive about 98% freeway. my car is a 4dr 1974 valiant 225 w/ a supersix and bbd. the car has around 300,000 on the original engine. it has never had any internal work just maintenance ( alt, water pump , belts, etc) im using a msd box for spark other than that its stock. And the rear ratio i believe is 2.94, i forget i swapped the old 71/4 for one that i found with 20,000 original miles because it had the higher numerically gears. I couldnt believe this guy found a 69 dart with 20,000 orig. miles, gutted it and made a drag car with it.
PostPosted: Mon Oct 27, 2008 9:49 pm
Next time I am at pull a part I will look for a 2.2 or 2.5 with a Holley.
PostPosted: Tue Oct 28, 2008 6:35 am
I suggest not the holley from 2.2. Chrysler only had 2.5L with TBI only.
Go weber, ebay will have few low miles weber carbs.
Cheers, Wizard
PostPosted: Tue Oct 28, 2008 7:56 am
Cheers, Wizard
Hey for $10 and don't plug in the wire on the top? Worth a try!
A friend who was a Chrysler tech said it would be good.
PostPosted: Tue Oct 28, 2008 10:34 am
I forget where I got mine from, but here a few places I got loaded. http://www.carburetion.com/Weber/weber.htm http://www.redlineweber.com/ http://www.weber-carbs.com/ http://www.racetep.com/weberX.html
If you run a 1bbl mainfold, you will need a the adapter for the manifold. If you have a 2bbl manifold, you will need a adapter to mount carb to manifold. Do some homework before you jump into this. Me with a van, I had to do some modifing to make this work, like I had to use a go cart cable instead of a linkage, also had to get some different throttle componets, etc. to make this work. Do a search here and see what comes up, as this subject has been discussed in the past. Any other Q's, just ask. Good Luck
Users browsing this forum: Amazon [Bot], Bing [Bot] and 9 guests
