It is currently Mon Oct 26, 2026 3:57 am
 Post subject: 3 ohm coil?
PostPosted: Mon Oct 27, 2008 10:29 am
If you run a 3ohm coil , can you remove/bypass the ballast resistor?
i seen it in some old posts and am wondering if its true and if so which coil (mopar EI installed on car ) is best?
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Mon Oct 27, 2008 11:22 am
The stock coil is around 1.5 ohms and the primary impedence around 2.4 mH. The stock point-type ballast is designed to get hot and increase resistance; roughly R= (0.5 + 0.633*A) ohms where A is the current in amps, while the stock electronic ignition ballast is about a constant 1 ohm.
Hence, I'd suggest you bypass the resistor or you'd decrease your available spark energy (at least at low RPM) by a factor of ~40-50% (assuming the coil impedence is the same).
 Post subject: pertronix 3ohm
PostPosted: Mon Oct 27, 2008 11:32 am
anyone run a pertronix flame thrower 3 ohm coil, bypassing the factory ballast resistor?
 Post subject: Re: pertronix 3ohm
PostPosted: Mon Oct 27, 2008 1:24 pm
Yep, I am! I did it quite a few months ago, and I bypassed the ballast. I have had no problems so far, and I love it. I am also running the stock ECU, but I want to get ahold of one of those orange ones, this one looks origional!
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Mon Oct 27, 2008 2:45 pm
Yep, no ballast and a Pertronix I for the points.
Runs good, and no problems starting.
 Post subject: sold
PostPosted: Mon Oct 27, 2008 2:54 pm
i'm sold! I don't like/want the ballast and keeping a extra one with me sucks,so for the $39.00 its gotta be one of the best deals ever :D
 Post subject: Re: sold
PostPosted: Mon Oct 27, 2008 4:08 pm
I think it was definatly a good deal!
PostPosted: Thu Dec 18, 2008 11:31 am
Anyone ever try the square 3 ohm HV Pertronix coil that mounts on the inner fender with out the ballast resistor? If so, how well does it work?
Thanks!
