It is currently Tue Nov 17, 2026 6:13 am
PostPosted: Tue Oct 28, 2008 9:07 am
Hi all,
I just had my 225 re-built and was informed the bolt that holds the balancer onto the front of the crankshaft was missing. It's a 1967, with automatic trans, in case that makes a difference. I haven't started looking for a replacement yet, but thought I'd ask if these are readily available anywhere? Thanks.
Roger
PostPosted: Tue Oct 28, 2008 9:27 am
Your slant was missing the harmonic balancer bolt from the factory most likely. Most didn't have them, and they aren't really needed. Still, if you want one, it's the same as for a small block V8.
PostPosted: Tue Oct 28, 2008 9:29 am
It's not missing, but you can get and install one if you want. See this post.
PostPosted: Tue Oct 28, 2008 9:36 am
Thanks very much for the quick reply, gentlemen. Another mystery solved.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 5 guests
