It is currently Tue Jun 23, 2026 1:56 am
 Post subject: duster help
PostPosted: Tue Oct 28, 2008 2:31 pm
hey guys today was a big turning point for me to day i just drive my duster for the first timesince i bought it about 1 1/2 years ago it was awsome well i got one problem...
i pulled in to my driveway after that ride i cant discribe in words, she choked off on me well i tryed to crank it just turned and turned well i got some more gas it crankedand choked off again found out while i stoped in my drive way i forgot i put on the parkin break then i took it off and i still choked off then i finaly got it runnin but when i was turning the car over it shot fuel stright up out of the carb (holly 1920 and i had the hood up) so whats up with my holly?
thanks josh
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Tue Oct 28, 2008 3:48 pm
check your distributor clamp bolt, you may have left it loose. check your timing. also, if your handbrake was on while you were driving a red warning light on the dash should have been alight.
PostPosted: Tue Oct 28, 2008 4:11 pm
you float is stuck in the carb and the full pressure from the pump is spraying fuel up through the air vent tube for the fuel bowl,you have to take the carb apart and clean it.
PostPosted: Tue Oct 28, 2008 4:20 pm
you might want to have someone observe the bowl vent to verify that before taking the carburetor apart.
PostPosted: Tue Oct 28, 2008 4:33 pm
l would go with steponmebbbboom and the timing , does it shoot gas out of the carb right after cranking with a whoof! sound ?
Dave
81 Dodge D150
It looked easier in the book .
 Post subject: Backfire
PostPosted: Tue Oct 28, 2008 5:42 pm
Timing is out of whack, when was the timing chain last replaced....
PostPosted: Tue Oct 28, 2008 5:56 pm
If the dizzy has been out, it may be 180 out.
My 02.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Oct 28, 2008 6:01 pm
this car has not been serviced and or worked in over 20 years and it is like it gets a huge surge form the fuel pump and then it dont want to crank and it has some evaporation gonig on in there
PostPosted: Tue Oct 28, 2008 6:12 pm
Sounds like carb rebuild time. REMEMBER DO NOT trade your carb in on a rebuilt from the parts store, there JUNK. Most of the rebuilders like Walker kits and parts.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Oct 28, 2008 6:27 pm
the carb was rebuilt by me and my dad
PostPosted: Wed Oct 29, 2008 6:35 am
the fuel that shot up out of the carb, was it a solid stream or a spray mist of fuel?
PostPosted: Wed Oct 29, 2008 8:36 am
I vote a sunk float. Had the same thing happen to me. Pull the bowl, and make sure that the spring that goes underneath the float is still there. If it is, throw a new float in it and set it to factory spec. It's hard to tell if it's too heavy or not, but if the difference is enough, you can feel which is heavier.
~THOR~
PostPosted: Wed Oct 29, 2008 1:29 pm
it was like a streem then pause and then another streem of gas
PostPosted: Wed Oct 29, 2008 2:52 pm
Sunk float or grit in the fuel inlet (between the needle and seat) causing it to stay open, thus the fuel pump keeps pumping more fuel to where it overflows and squirts out.
Install a new needle and seat and or float, then reset the float level per the book, about 7/8" down from the top (when measured from top of the casting after removing the power valve). You can let it idle with the top off to get a good measurement.
PostPosted: Wed Oct 29, 2008 3:18 pm
Sounds like a prostrate problem.........
