It is currently Wed May 20, 2026 4:05 am
 Post subject: drum brake q's
PostPosted: Thu Feb 13, 2003 11:00 pm
Two things..
When going from 9" to 10" brakes, can I keep the same master cylinder or do i need a bigger one for more volume?
Also the front spindles, between the 9" and 10" brakes, are they the same?
PostPosted: Fri Feb 14, 2003 5:42 am
You can keep the same MC, although you might want to add an aftermarket adjustable proportioning valve to get the front/rear bias right again.
The spindles are not the same, from all I've heard...
PostPosted: Fri Feb 14, 2003 8:48 am
Sorry, spindles and wheel bearing sizes are not the same between the 9 and 10 inch drum brakes. :(
 Post subject: hmm...
PostPosted: Fri Feb 14, 2003 1:20 pm
I may as well leave the front 9" as is then and just change the back along the axle. Then when I figure out what I'm going to do with disc brakes I'll swap front spindles so I don't have to take apart the front end twice. Unless the 10" drum spindles are the same as the disc brake spindles. but somehow I doubt that I'd be that lucky either :(
PostPosted: Sat Feb 15, 2003 6:22 am
Yep, just wait and go to discs up front. They are the best setup. I don't know about spindles between 10" and discs, but I think they are different too.
Users browsing this forum: Amazon [Bot] and 3 guests
