It is currently Tue May 19, 2026 10:38 am
PostPosted: Thu Oct 30, 2008 10:03 am
Hi
I am going to try to change the axle oil seals on a 65 valiant but looking at the manual this looks nasty. How do I disconnect the axle from the differential gears? What is this bearing that has to be pressed? Can I just remove the bearing and take it to a place with a press then reinstall it?
Any suggestions?
PostPosted: Thu Oct 30, 2008 12:11 pm
The axle shaft will simply slide-out of the splines in the differential's side gears. It is the axle bearing the usually gets 'stuck" into the end of the axle housing and needs a BFH or puller to get out.
Once the axle is out, take it to a automotive machine shop and they can R&R the bearing.
PostPosted: Thu Oct 30, 2008 3:35 pm
Make sure the axle shaft is not worn when you have the bearing replaced, i posted my experiences on that project in july, read on:
for anyone who did a search and came up with this thread, i will relate my experiences with wheel bearings on my 7&1/4" axle:
a failed wheel bearing on my axle (an already existing problem when i bought the car) manifested itself not as a squeak, but as a steady grinding noise that increased in sound level, not pitch, as my road speed increased. imagine driving on smooth silky new asphalt and then transitioning to old asphalt where the stones in the mix are raised: the road noise increases. well, that's what this sounded like. just loud road noise.
when i investigated, i found a line of axle oil coming from the axle shaft seal, and about 1/16" of radial play when moving the axle shaft up and down. i used a slide hammer as recommended by chrysler when removing the axle shaft, after unbolting the flange from the backing plate.
when i removed the remnants of the bearing, i found that the inner race had worn down the shaft surface in that area. rather than trying to locate another axle shaft, i repaired this one. i took it to north american hard chrome to be spray-welded and remachined to the correct thickness. they used the other shaft as a reference. they had to observe the seal diameter, and the press-fit diameter where the bearing resides, as well as where these diameters transition to each other for maximum performance of the bearing and seal. total cost was $90 and turnaround time was 2 business days.
a more cost-effective solution to spray-welding could be using an advanced repair polymer such as belzona, and i am experimenting with that on a front hub. stay tuned to the suspension and brakes section for updates on that project.
PostPosted: Fri Oct 31, 2008 10:53 am
thanks for the suggestions
I am going to do both axle seals on the same day. If I pull out both axles will there be problem dealing with the differential gears? I mean will I have to use some sort of special tool to realign things?
PostPosted: Fri Oct 31, 2008 11:12 am
No problems... if it is an open differential. (Not a limited slip)
The axle shafts will slide back-in with-out any fuss.
PostPosted: Tue Nov 04, 2008 3:18 pm
after spraywelding the axle shaft it is put in an oven, heated, cooled under controlled conditions, then machined with a surface grinder so as not to reheat the metal.
yes, the bearing began to break up and that is how the inner race came loose.
