It is currently Sat Jun 13, 2026 1:13 pm
 Post subject: Harmonic Balancer
PostPosted: Sat Feb 15, 2003 9:23 pm
I haven't seen any talk about harmonic balancers. Seems that it would be most critical on 6 what with a long crank. Does anyone have a favorite or would a stock one do on a mildly modified engine? Mild meaning, head work, mild cam, headers, manifold carb, etc. etc.
go fast, turn left, don't screw up.
WWW.Mopardropheadcoupe.com
PostPosted: Sun Feb 16, 2003 5:30 am
I have a stocker on my motor, and it's pretty much as you described. A Fisher or Fluidamper would be better, but on a street motor you end up with pulley alignment problems. :shock:
PostPosted: Sun Feb 16, 2003 6:43 am
You are going to have to make the change...........stock ones tend to slip........then add nos??????????
Will
PostPosted: Sun Feb 16, 2003 12:05 pm
The really fast guys (in the 10s) I've talked to use either Fisher or ATI dampers, and say the fluid-type dampers are junk. You can use a BB Chrysler damper.
PostPosted: Sun Feb 16, 2003 9:56 pm
I use the Fisher damper on my dragcar, it is the same as the Bb Mopar and it sticks out aways from the t. chain cover, that was until I faced-off some of the hub, now it tucks right up to the cover.
As noted, the real pain is repositioning all the pulleys, a factory SL6 damper has the V belt groove right in the damper ring, none of the aftermarket ones have that so all the grooves have to be moved forward.
 Post subject: Harmoic Damper
PostPosted: Wed Nov 12, 2003 3:01 pm
HEY THERE GUYS, THIS IS TIM FROM FISHER DAMPERS.
WE HAVE A NEW DAMPER THE FITS IN THE STOCK LOCATION , PULLEYS LINE UP.
WE MADE A COUPLE OF THEM THAT WERE OFF ABOUT .200 ,BUT NOW WE HAVE THE CORRECT ALINMENT .
NOT ON ARE WEB SITE YET BUT WE DO HAVE THEM
WWW.FISHERCONCEPTS.COM
PostPosted: Wed Nov 12, 2003 8:54 pm
I'm not sure Fluidamper is still around, not that I would buy one, they are heavy.
Cecil
PostPosted: Thu Nov 13, 2003 8:35 am
Hi Tim,
I looked at your website, and I cannot tell the price or how to order a damper from you. Can you give us a price?
PostPosted: Thu Nov 13, 2003 9:00 am
Tim listed the price at $295 in the 'Zilla Killa engine build' thread.
Cecil
PostPosted: Thu Nov 13, 2003 12:30 pm
WELL .$295.00 IS OUR LETS SAY 5 PRICE, RETAIL $431.00 JOBBER $325
TO ORDER JUST E-MAIL ME AT FISHERCON1@AOL.COM /
WITH NAME, ADDRESS, AND PHONE NUMBER, THEN WE WILL CONTACT YOU TO GET ALL OTHER INFO. AND GIVE YOU A ORDER# SO WE CAN TRACK ORDER IN HOUSE,
THANKS TIM LIGHTFOOT@FISHERS
Users browsing this forum: Bing [Bot] and 5 guests
