It is currently Wed Nov 18, 2026 3:53 am
 Post subject: Bad water leakage
PostPosted: Mon Nov 03, 2008 8:16 pm
I've been having problems with water dripping down back behind the kick panel on the drivers side so I decided to take off some of the trim to get a better look. As far as I can see, water is dripping out between the metal on the A Pillar. Theres no visible water on the outside of the metal, but where the 3 or 4 layers of metal come together for the A Pillar, theres a constant drip from there between the layers. Is this a sign of a windsheild leak? I can't really run a water test since it's raining so I was wondering if anyone has ever had this problem or knows how to remedy it. Thanks.
