It is currently Mon Nov 16, 2026 12:09 pm
PostPosted: Tue Nov 04, 2008 8:34 pm
I've stumbled across this website http://koti.mbnet.fi/trc/teknik.htm in the past but can't identify all the parts use or the language of the description. Looks like a stock forged crank, clifford rods?, and a pretty clean set of custom headers.
PostPosted: Tue Nov 04, 2008 9:34 pm
We've discussed the car before. Try this link: http://koti.mbnet.fi/trc/etukeski%20eng.htm
PostPosted: Tue Nov 04, 2008 10:45 pm
I was dreaming up a turbocharged blow-through TBI system utilizing the megasquirt v2 and a heat exchanger to help fully vaporize the fuel mixture.
From what i understand a slant 6 with forged crank, arp rod bolts, stronger valve retainers, and improved camshaft lubrication should handle over 500 horsepower?
PostPosted: Wed Nov 05, 2008 7:31 am
500 hp should be safe from what I've heard if you can keep it out of detonation (and you will probably want forged pistons), but I would go multi-port instead of a TBI as you're likely to get better fuel distribution that way.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
Users browsing this forum: Ahrefs [Bot] and 5 guests
