It is currently Mon Nov 16, 2026 12:14 pm
 Post subject: carbs again
PostPosted: Wed Nov 05, 2008 3:25 pm
hey guys i was on chragslist the other day looking up stuff and they had some big holleys and edelbroks of like 75 bucks i was wondering how BIG can i gowith my offy and slant
thanks josh
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Wed Nov 05, 2008 3:28 pm
Site Admin
What mods have you made to the engine?
If it's stock, 500cfm or smaller.
If you've bumped the compression up significantly, and installed a big cam, you can breath a 600 cfm.
CJ
PostPosted: Wed Nov 05, 2008 6:16 pm
thats what im planning to do this winter
PostPosted: Wed Nov 05, 2008 6:55 pm
Site Admin
Do you have a specific build in mind?
CJ
 Post subject: Wink....
PostPosted: Wed Nov 05, 2008 7:04 pm
.080 over
mill block and head to acheive 12.5:1 compression
300 degree advertised duration camshaft with a 102 LSA and .680 lift
Substitute the valve springs for the ones out of a coil over suspension from a 1965 Lincoln Continental
Use Valves from a 351-4V Cleveland even though they don't fit (use more assembly lube you can force them in there...just notch the bore enough so you can use the leak fromthe water jacket to supress detonation like water injection on steroids)
Use late model forged crank but use an angle grinder to bob the counter weights to drop some rotating mass...
:roll:
Hang on I'm going back to Bench Racers anonymous....
:wink:
-D.idiot
PostPosted: Wed Nov 05, 2008 10:24 pm
:shock: .... Oh My lord..... I'm gona borow your build.....
Even in moderation i am excessive!
 Post subject: Re: Wink....
PostPosted: Wed Nov 05, 2008 11:52 pm
.080 over
:roll:
:wink:
-D.idiot
Bench Racers Anon for recovering psycho build ideas!!!! :twisted: The only issue I see is finding a large enough valve cover and corresponding hoodscoop to make the coil overs fit.... that could be a toughie! :D
*Digs through JC whitney catalog for "grave digger" monster truck parts.... :roll: *
LOL
I agree w/Ceej, however, 500cfm is quite a monster for a stocker! You would need to jet it down a bit I think...
~THOR~
