It is currently Sat Nov 21, 2026 8:18 am
Post new topic  Reply to topic  [ 98 posts ]  Go to page Previous 1 2 3 4 5 … 7 Next
PostPosted: Thu Nov 06, 2008 1:44 pm
Remember to run 2 1/4 pipe no larger or smaller.
Frank
Why not 2 1/2 pipes? I was thinking about going 2 1/2 back to the muffler and 2 1/4 dual outs.
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Thu Nov 06, 2008 2:56 pm
ya sure a used one and hobart makes some cheap good ones what do you mean by cheap?
87 d150 2bbl carb 225
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
89 f450 diseal 4x4 dually 5sp
PostPosted: Thu Nov 06, 2008 3:30 pm
Is there any such thing as a cheap MIG??
Joe
Harbor Freight on sale...........
I haven't had any problems with mine.
But I wouldn't recommend the gasless MIGs. Welds are much cleaner (no slag) with at least CO2.
PostPosted: Thu Nov 06, 2008 4:19 pm
Bigger is not necessarily always better. You want to keep the exhaust velocity up at the head of the system; too large a pipe spoils that. Besides, the manifold outlet is 2". You can hone it a little to 2 and a fraction, but 2½" is going to make it basically impossible to seal the headpipe flange to the manifold outlet.
PostPosted: Thu Nov 06, 2008 8:47 pm
So 2 1/4 is absolutly the largest I should go?
PostPosted: Thu Nov 06, 2008 8:48 pm
Joe
slag isnt bad... if u weld right
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
PostPosted: Fri Nov 07, 2008 4:33 am
So Dan, Is 2" the right way to go or 2 1/4"?? It would seem that to keep it simple (the old KISS works for me) would be to go with 2" or is that too constrictive? I don't want to start a raging debate here on size!!
Thanks.
Joe
PostPosted: Fri Nov 07, 2008 6:20 am
There's no reason to use 2" or 2½" instead of 2¼", which is a known-good size from every perspective (function, fit, etc.).
PostPosted: Fri Nov 07, 2008 9:14 am
I guess I'm confused about the exhaust outlet being 2" working with 2 1/4" pipe??
Joe
PostPosted: Fri Nov 07, 2008 12:20 pm
It works fine (the factory did it that way starting in '76).
PostPosted: Fri Nov 07, 2008 2:45 pm
Dan, I'm sorry, you're going to have to walk me through this. You've got a 2" hole in the exhaust outlet, how do you stuff a 2 1/4" pipe in there??
Pictures might help. Once I get the concept I'm fine, but until then.....
Thanks .
Joe
PostPosted: Fri Nov 07, 2008 2:47 pm
Thanks .
Joe
You don't.
The exhaust diameter steps up to 2.25" at the exhaust flange that's flush against the exhaust manifold.
PostPosted: Fri Nov 07, 2008 3:53 pm
Dan, OK I get it now.
Thanks.
Joe
PostPosted: Fri Nov 07, 2008 4:10 pm
Hey, I'm doing that tomorrow (going from 2" to 2.25")! :mrgreen:
PostPosted: Fri Nov 07, 2008 7:24 pm
Whats the best muffler for a nice deep sound, but its still pretty loud? I was thinking a flowmaster 40 series.
