It is currently Wed Nov 18, 2026 12:28 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Sat Nov 08, 2008 7:44 am
I am startingto suspect I have a jumped timing chain more than anything else
Bring it as close to TDC when the rockers are loose, and then make a new mark on the damper....
rock... it ain't all about you.
I didnt reply to the original question because i'm not all that interested in it. I already gave that information a couple weeks ago, doing a search on this site would have retrieved it easily:
http://slantsix.org/forum/viewtopic.php ... ht=#209067
Use the search, luke.
PostPosted: Fri Nov 14, 2008 10:58 am
Gentleman, Thank you for all your replies. Timing chain situation seemed ok. Finally found problem: one of my two wires coming out of distributor had worn thru the rubber bushing and was arcing to distributor ground.. Has anyone else ever seen this before? 3 weeks of on-off searching with a total investment of like $22. Guess thats better than a 3 day repair on my VW that costs $1700. LOL. Thanks to all of you again. dave
PostPosted: Fri Nov 14, 2008 2:15 pm
Congratulations on your troubleshooting!
That's sneaky.
Cheers, Wizard
Users browsing this forum: DuckDuckGo [Bot] and 8 guests
