It is currently Wed Nov 18, 2026 1:09 am
PostPosted: Sun Nov 09, 2008 12:30 am
I finally got a 2 1/4" pipe from the manifold to muffler (a Magnaflow) today, keeping the 2" tail pipe. Will I need to change the jetting on my Holley 1920 to compensate for the larger diameter exhaust pipe? I'm running a #58 jet now.
PostPosted: Sun Nov 09, 2008 1:00 am
Naw.... but you may be tempted to go larger... make it go faster!
~THOR~
PostPosted: Sun Nov 09, 2008 5:59 am
simply fattening the main jet will not make you go faster unless you are already running lean.
go out and enjoy your new exhaust for a while, then come back and read your plugs. go up or down depending on what they tell you.
PostPosted: Sun Nov 09, 2008 10:21 am
Eric,
No, you don't need to go fatter. Stick with the #58. I have gone as low as a #55 just to see what would happen. A #57 is what I am running which is right on the edge, the #58 gives much better vacuum readings and keeps you out of the power valve a little more.
PostPosted: Sun Nov 09, 2008 11:09 am
Hi
As I understand it the moment you go from stock to headers with free flow system there is sometimes an enrichment needed
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Wed Nov 12, 2008 9:49 pm
Depends, if your car starts to surge, then you need bigger main jets.
PostPosted: Thu Nov 13, 2008 10:53 am
What he said.
PostPosted: Thu Nov 13, 2008 11:15 am
I went up to a #60 and played around with the emulsifier screw. Car seems to like it, with a little more umph in the mid range. Car is louder with bigger pipe, thats for sure.
PostPosted: Thu Nov 13, 2008 3:43 pm
See, toldya you wouldnt be able to resist putting a fatter jet in there! Goes faster! :D
~THOR~
PostPosted: Thu Nov 13, 2008 3:49 pm
Eric,
How big (in drill size) would you say your idle air bleed is now that you opened it up with the brass screw adjuster?
I have gone as high as a 61-2 with out going below 23 mpg with a .035 diam. hole which is the same as a #65 drill bit.
It is surprising how much more power you unharness with a little bigger exhaust pipe! :D
PostPosted: Thu Nov 13, 2008 4:03 pm
I get a bigger oil smoke screen also.... :?
Everything on the carburetor is stock Ted, so I don't know the size.
PostPosted: Thu Nov 13, 2008 6:10 pm
Eric,
Ok, how many turns out on the brass idle air bleed screw did you go? I will compare with on of my other carbs down stairs.
 Post subject: Like...
PostPosted: Thu Nov 13, 2008 6:51 pm
Like what 10-15 hp tops with the stock cam, and maybe about 10 ft/ lbs of torque....just enough to shift the torque curve a bit, and make a little better mileage...
-D.idiot
PostPosted: Thu Nov 13, 2008 8:59 pm
Eric,
Ok, how many turns out on the brass idle air bleed screw did you go? I will compare with one of my other carbs down stairs.
Only about three quarters of a turn. It's really sensitive. If I just turn it out a tiny bit the vacuum and idle quality goes down. If I turn it in all the way, it will still idle fine but the engine starts shacking a little bit. Like I said, real sensitive.
PostPosted: Fri Nov 14, 2008 12:32 am
Its a bitch keeping my foot out of it....burn more oil ya know. :(
Users browsing this forum: Amazon [Bot], Bing [Bot] and 4 guests
