It is currently Mon Nov 16, 2026 11:30 pm
 Post subject: Torque
PostPosted: Sun Nov 09, 2008 12:29 pm
Wonder what the end result with efi - torque improves as a rule and the ram type manifold will be combined with a dual exhaust system following the design ideas from the mopar museum visit one of our members had
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
 Post subject: Mid range...
PostPosted: Sun Nov 09, 2008 1:05 pm
The only thing that will help is the EFI will keep the long ram puddling problem from happening... the part that will make things more interesting is to see if the 'pulses' in the ram range will be slighted by not having to carry a load of fuel with the pulse... if the air charge down the runner is still pulsing somewhat, it may become a fun exercise in trying to dial in the injectors to provide 'normal' operation at the street level... then up the duty cycle a bit to have more fuel available when ram effect kicks in...
The EFI's effect on torque won't be as significant as the long ram manifold's effect on low/mid range torque in the band...
Been there, drive that daily...still scratching out some of the 'fun' on the programming for the next step.
-d.Idiot
PostPosted: Sun Nov 09, 2008 1:06 pm
What EFI are You using?
Regards,
Fanie Gerber
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 2 guests
