It is currently Thu May 21, 2026 5:25 am
 Post subject: Dampers
PostPosted: Sun Nov 09, 2008 12:09 pm
OK another fiction or not question
Is it true that you can use a RB damper on a slant? apparently the crank nose an those V8's and the slant is the same
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
 Post subject: Yes
PostPosted: Sun Nov 09, 2008 1:00 pm
Yes you can use the B/RB harmonic balancer. of course your on your own for a timing mark...
PostPosted: Sun Nov 09, 2008 1:50 pm
Also, the pulleys will not line up.
PostPosted: Mon Nov 10, 2008 3:28 am
I would try to get a Romac Slant 6 balancer from Oz. Nice unit, not too expensive, and endorsed by Cameron Tilley...
PostPosted: Mon Nov 10, 2008 7:27 am
http://www.romac.com.au/
0224 or 0224SA,depending on your want.
good stuff.
regards Rod :D
PostPosted: Mon Nov 10, 2008 8:43 am
bb dampers work but you have to change the timing cover seal to a bb seal and with the belt groove have one machined into the thick part of the damper and you can use the stock belt locations
PostPosted: Mon Nov 10, 2008 12:15 pm
Do all slants come with dampers? Mine is a '74 I didn't think it had one but I could be wrong. What is the advantage of adding one if it dosent?
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Mon Nov 10, 2008 12:41 pm
All engines have vibration dampers, including all slant-6s, including your '74. It is integral with the crankshaft pulley.
PostPosted: Mon Nov 10, 2008 12:58 pm
WHY I asked this question -
1 RB dampers are easy to get over here slanties not
2 I was wondering how to eliminate the dreaded outer ring slip
This said - the romac units are nice
Just wonder which will be best - the steel or ally outer ring
Regards,
Fanie Gerber
PostPosted: Mon Nov 10, 2008 1:05 pm
There's no need to eliminate the inner-hub/outer-ring construction. They work fine for decades!
PostPosted: Mon Nov 10, 2008 2:25 pm
Thanks Dan, sometimes its better to ask the dumb questions than to remain ignorant.
PostPosted: Mon Nov 10, 2008 7:37 pm
As long as we're talkin dampers,Hows come my 80&83 truck slants have such a BIG weight compared to others I see?Does that have to do with the lighter crank(13-14# less)?If so what happens when swapping older/newer balancers on older/newer cranks?Just another question that keeps me awake at night :? :)
PostPosted: Mon Nov 10, 2008 7:39 pm
I have a cast crank engine with a standard damper on it.. I suppose it is possible that since yours is a truck engine, that they put maybe a V8 damper on there?
~THOR~
PostPosted: Mon Nov 10, 2008 7:50 pm
No. Slant-6 engines always and only got slant-6 dampers. V8 engines always and only got V8 dampers.
