It is currently Fri Jun 19, 2026 6:48 pm
 Post subject: exhaust
PostPosted: Fri Nov 07, 2008 4:51 pm
I would like to know the best setup for dual exhaust on my 1987 D150 keeping in mind I want good sound and performance on a tight budget any help would be appreciated
PostPosted: Fri Nov 07, 2008 5:07 pm
How tight is your budget? There is no sense in doing anything dual if you're going to keep the single-outlet stock exhaust manifolds. If your budget will cover it (plus the necessary pipework), get Dutra Duals.
 Post subject: 2 1/4 "
PostPosted: Fri Nov 07, 2008 5:42 pm
a 2 1/4" single is good enough for any non race build, and cheaper too ..
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Mon Nov 10, 2008 8:54 pm
thanks guys I appreciate the tips I eventually want to get a set of truck headers and 4brl
 Post subject: Hmmm...
PostPosted: Mon Nov 10, 2008 9:38 pm
1987 should already have the 2 1/4" pipe... which is there to make up for that nasty late model setup where they used a small cat. convertor to hook to the AIR, then a few feet down they used the standard Cat. convertor to make sure that a) it passed emissions... then b) strangled the $^%&^ out of it...
Check your local laws... if no inspection/smog check just getting the old original cats out of there will help loads... if you have to smog... finding a nice cat-back with a larger input/output pipe size and using a suitable pipe setup will help keep you in check, and keep your power up.... (make sure tune up and carb are in good shape...)
PostPosted: Tue Nov 11, 2008 8:42 pm
no kidding they did a good job of choking the crap out of them the V8 guys had to deal with three of the cats
PostPosted: Tue Nov 11, 2008 9:23 pm
Heres my exhaust that was around $100 for parts and labor. Its 2.5" piping with a single cherry bomb. the cherry bomb is only $20. asuming this is the sound you want?--->
http://www.youtube.com/watch?v=bUcZCHH7Trc
Just an idea for you
PostPosted: Wed Nov 12, 2008 3:16 am
that is great sound and that is what I was looking for thanks that is a beautiful duster you have
