It is currently Mon May 04, 2026 5:21 am
 Post subject: Remflex Gaskets
PostPosted: Fri Jul 18, 2008 2:54 pm
I Just Put A remflex Gasket on My 79 Volare It's very Nice And I have no Problems Only had to torque to 5 ft/Lbs..
The Gasket set includes the intake / Exhaust manifold combination and the HotBox carb Heat gasket... I cant comment on the Hotbox Gasket as I did not use it yet.
www.remflex.com
http://catalog.remflex.com/category_s/87.htm
PostPosted: Tue Oct 28, 2008 9:53 am
I have used the RemFlex hot box gasket and the header pipe gasket. They are awesome! You couldn't ask for a better gasket. :D
PostPosted: Tue Oct 28, 2008 2:49 pm
I have not had bad luck with the Fel-Pro gaskets. Im not sure why everyone does not like them. They were waayy cheaper than the Remflex. Of course, the Remflex is probably waayy better.
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Wed Nov 12, 2008 11:11 am
we are a remflex dealer so i am a bit biased, but i was going thru flange gaskets like candy, tryed the stock felpro, the next step up the NEA flange gasket with metal ring. finally i have a remflex and no more leaky exhaust problems. the gasket crushed real nice and it does not leak! we also have remflex samples that we keep around and i have made gaskets from the sample blank stock that work great!
it's more money but it sure solved my problems
PostPosted: Wed Nov 12, 2008 11:52 am
Midi-
have you checked the mating surfaces on the exhaust manifold and the pipe? I have had the same problem (burning through "doughnuts") and it is usually caused by (a) a rough sealing surface or (b) torquing one of the bolts tighter than the other.
PostPosted: Wed Nov 12, 2008 1:19 pm
i'll take (A) a rough sealing surface
the flange/pipe was pretty beaten up.
PostPosted: Thu Nov 20, 2008 8:19 am
Remflex is the OZ gaskets? Ineed to replace my cracked exhaust on the Dart one of these days.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Thu Nov 20, 2008 11:59 am
No, Remflex is one of the two suppliers of worthwhile slant-6 manifold gaskets. The other is It is very much worth your while to get the this outfit. Both are good quality gaskets, but I tend to throw my support behind the Australian outfit. Not only do they ship the gaskets to North America lightning fast and cost-effectively, but they are also developing high-tech head gaskets for multiple versions of the slant-6, and I like to support them in that effort (not only sending them $$ for manifold gaskets, but also demonstrating to them that slant-6ers are a big enough market to make parts for).
 Post subject: They look good...
PostPosted: Sat Nov 29, 2008 6:02 pm
Just as an FYI, as of 2006 Mr.Gasket discontinued their 'fat' paper gasket...
In Salem, OR Performance Racing Equipment on the Corner of Portland Rd. and Pine St. in Salem is now carrying Remflex gaskets... looks like about $15 per gasket for the slant-6 (which is about $2 more than the Mr Gasket 320G used to go for. I got to look at a remflex gasket for a 351C and they look pretty good.
-D.idiot
