It is currently Mon Jun 15, 2026 7:13 pm
 Post subject: Bouncing speedometer!
PostPosted: Tue Nov 18, 2008 11:07 am
I had a problem on my '73 Dart a few months ago where the speedometer needle was dead. I asked about it here and eventually pulled the cable which was frayed apart inside. I went to Napa and got the right one (it fit perfectly) and all was well until last week. Now, the needle bounces from 0 to 100 (or higher) regardless of my road speed. It's as if the cable were rapidly hanging up then letting go inside it's tubing (I can sort of hear this). And sometimes the needle will stick at some mph when I shut it off. Usually tapping on the dash will drop it back to 0.
Are these Napa cables lubed inside, and if not, what's a good lube to use? Thanks!
________
XS-1
PostPosted: Tue Nov 18, 2008 11:31 am
Take a look at
http://www.slantsix.org/forum/viewtopic ... 926#161926
PostPosted: Wed Nov 19, 2008 10:30 am
If lubing doesn't help: I've found that it was easy to accidentally stretch my '74s cable slightly and make it a just tad too long, causing it to bind. The test is to not put it on quite all the way (giving it a little extra slack) and see if it stops binding.
I shortened my cable at the speedometer end slightly using a Dremel tool with a #409 cutoff wheel and all was well.
PostPosted: Wed Nov 19, 2008 4:10 pm
Interesting! I'll try the lubing this weekend. KBB, how much do you figure that you cut off?
________
Jaguar XJR-9
PostPosted: Thu Nov 20, 2008 5:22 am
The same thing happened to my 73 Dart. Speedometer needs rebuilt.
PostPosted: Thu Nov 20, 2008 8:12 am
I broke my needle back in January. I was running about 80 and it was doing the bouncy thing and snapped.
PostPosted: Thu Nov 20, 2008 9:46 am
I cut off about 3/16"; the #409 wheel made it a nice clean cut. I had pulled on the cable (not all that hard, or so I thought) getting it out and it stretched out but didn't return to its original length as I'd expected.
