It is currently Fri Nov 20, 2026 4:47 am
 Post subject: Changing rocker ratio
PostPosted: Sun Feb 17, 2008 5:07 pm
I gained some experience cutting and welding rocker arms on my hemi head project so I thought I would try it on some stock slant rockers.
I checked a few and they were around 1.47 to 1. By cutting 1/16" gives a 1.55 ratio, cutting 1/8" gives 1.65 ratio. Since they are steel they're easy to weld. You can also compensate for pushrod length when welding. Cheap way to increase rocker ratio.
Franklin
'61 Valiant
PostPosted: Sun Feb 17, 2008 5:40 pm
Will the pushrods clear the head?
PostPosted: Mon Feb 18, 2008 12:36 pm
They should clear the head, I only cut 1/16" on this rocker. If you go 1/8" there may be some grinding needed.
Franklin
'61 Valiant
PostPosted: Mon Feb 18, 2008 3:10 pm
You da man, Mr. Heck.
PostPosted: Thu Nov 20, 2008 4:40 pm
Very interesting...
1969-1/2 Dodge Super Bee A12 (440 Six Pack, 4-spd, Dana 60)
1974 Plymouth Duster 360 (4-spd, 8.75")
1973 Plymouth Duster (225, auto, 8.25")
2001 Dodge Ram 1500 QC 2wd (5.9L, auto, Dana 60)
PostPosted: Thu Nov 20, 2008 5:15 pm
that adjuster is an interference-fit, and you are cutting and welding that end of the rocker, has this disturbed the clamping force on the adjuster threads?
