It is currently Sat Jun 13, 2026 4:59 am
PostPosted: Sat Nov 22, 2008 12:51 pm
Car Model: 1964 Plymouth Valiant 225, 1977 Dodge D100 225
I just visited the local U-Pull-It and I think I bought the right parts for the HEI conversion, but I'm not sure. The coil is from an early 90s Blazer V6 and the module is from a late 80's GMC truck with a SBC V8.
Thanks for your help!
Chuck and the Flying Valiant
PostPosted: Sat Nov 22, 2008 1:25 pm
Coil looks fine, but you need an ignition module with 4 pins. Try to get one of the real GM ones. They are better than most parts store replacements.
PostPosted: Sat Nov 22, 2008 2:33 pm
Oh well. Thanks for your help. I'll keep looking.
PostPosted: Sun Nov 23, 2008 2:31 am
hi chuck get the 4 pin module - you do actuaaly get a coil hei module combo that is quite neat
the 4 pinHEI module is about ~$12 over here (R140)
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Sun Nov 23, 2008 5:31 am
Hi Chuck,
I think you will find the E-core GM coil is a hot and reliable coil. Maybe one of the best buys available from the pick-n-pull.
I guess I'll have to keep looking. I saw no RWD GM cars and no GM trucks with a four pin module. Does anyone have a list of what cars have them and where they're located in the engine bay?
PostPosted: Sun Nov 23, 2008 6:02 am
Chuck, your better off buying new from a part store. They are not much money. Time is money, and you will spend a lot of time looking. They are located inside the distributer of the early HEI units. The one from the 80's with the big cap, that has the coil in the cap. I can get a part number, later, when I go out to the shop.
PostPosted: Sun Nov 23, 2008 6:06 am
Thanks, Charlie. I think you're right. It took forever just to find a coil that was accessible, and with the poor selection they had at the Gainesville yard, I may never find what I'm looking for.
Users browsing this forum: Amazon [Bot] and 1 guest
