It is currently Sat Nov 21, 2026 3:00 am
 Post subject: q-jet on a slant?
PostPosted: Sun Nov 23, 2008 5:44 am
hey last night after work me and one of my chevy frends hung out and i was telling him about my 4bbl manifold i bought and that i needed 4bbl well we went down to the shop where hes working on his 57 chevy and i asked him if he had eny carbs well he gave me a good quadrajet and addapter so my question is has eny one tryed a q-jet on a slant befor?
thanks josh
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Sun Nov 23, 2008 6:04 am
I have never done it, but always thought it would work well. It will most likely require some tuning on the carb.
PostPosted: Sun Nov 23, 2008 7:02 am
I have two. One on my 360. I have a much better inventory of Thermoquads (insert Slantzilla's opinion of TQ's)
Metering rods and jets are easier to find than TQ's. The airvalve on the secondaries will adjust the airflow via engine demand. So in theory you can't over carb your engine.
Theu do not like a lot of fuel pressure.
GM built some of their OHC sixes with the Qjet.
PostPosted: Sun Nov 23, 2008 11:21 am
Hey, Rug; any chance of a Furd or I-H version of a TQ in your pile? They had a self contained ("black dial") choke rather than having to use a stock Mopar well-style choke.
PostPosted: Sun Nov 23, 2008 12:01 pm
I have a Quadrajet on my 225 and I like it better than the 625 CFM AFB I was using before. I'm still working on a disc brake upgrade so I haven't had much of a chance to drive it and get it jetted properly. It runs fine with the Chevy jetting but it needs tuning for best fuel economy and power.
Slant Six Quadrajet
PostPosted: Sun Nov 23, 2008 4:35 pm
cant wait to hear that dooo-woooo of that nasty little q jet with an open eliment filter :twisted:
PostPosted: Sun Nov 23, 2008 7:05 pm
I think I have a I-H version. It doesn't have an electric choke.
PostPosted: Mon Nov 24, 2008 10:23 am
Slant Six Quadrajet
You sure you want to run your fuel line to that Qjet like that? :?:
PostPosted: Mon Nov 24, 2008 1:37 pm
This arrangement hasn't caused me any vapor lock problems in the past and is the same as the 1bbl routing. However, I may try the fuel line routing recommended by SlantSixDan when I finally start driving it again.
PostPosted: Mon Nov 24, 2008 2:42 pm
Keep in mind if you race IIRC only 6" of rubber in the fuel system total to pass tech.
PostPosted: Tue Nov 25, 2008 4:45 pm
12" here... muwahahah!
I want to try the Q-Jet on my slant soon as I get a manifold.... and a Q-jet off of a 3.8 Buick.
~THOR~
