It is currently Mon Jun 08, 2026 10:14 pm
PostPosted: Sun Nov 23, 2008 2:03 pm
Hey whats the best combo for front and rear brakes that is a 5x4.5" lug pattern? I want to do front disc brakes and 10" rear drums (carbon metallic) from later mopars but am open to custom fabrication to fit corvette brakes or something.. Can i take the front end from a 73-80' Dart, Demon, or Swinger?
Thanks,
Aaron
PostPosted: Sun Nov 23, 2008 4:15 pm
Yes
You need the UCA , spindle , caliper and rotor off a 73 - 76 Dart etc
You also need the master cyl and prop valve
Get the rear axle out of the same car and you are set.
It took all day for me to disc brake my 65 with the 75 donor car beside it.
PostPosted: Sun Nov 23, 2008 4:43 pm
I don't know, these days I am leaning towards 10 inch all wheel drums for a daily driver. Less rotating mass and less drag. So long as you aren't autocrossing or towing a trailer all wheel drums should be fine. Adding a power booster wuld be even better.
PostPosted: Sun Nov 23, 2008 4:49 pm
Do the later year mopars have 10" drum brakes on the rear? Can the stock disc brakes be upgraded with bigger discs/calipers?
I have these hella old school Appliance wheels with spinner caps off of a 65' mustang i would love to use and would be a nice bonus to some real stopping power..
PostPosted: Sun Nov 23, 2008 4:59 pm
Well, the later drums were also 5 x 4.5 front and back. There are aftermarket upgrades for brakes, but unless you are doing some SERIOUS driving you will not need more than the stock 73-76 disc/drum setup.
I once parted a 74 Valiant sedan that had 11 inch drums on the rear, but that was the only one I saw. Ten inches is pretty common.
PostPosted: Mon Nov 24, 2008 7:05 am
Just my opinion, for what it's worth. If I were going to the trouble to swap out the brakes I would definitely go with the front disks. It's true that the drums work and are perhaps adequate for light duty use but for the time, trouble and money I would do the disks.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Nov 24, 2008 1:53 pm
I like the late-A 10.87" front disks I put on my '64 Valiant. If I need more, there's a set of 11.75" caliper adapters in my garage - just add rotors!
HERE are some options.
Out back, the easiest upgrade to a 4.5" bolt pattern is with a rear-end swap.
PostPosted: Mon Nov 24, 2008 2:28 pm
Actually, the late A-body 10" drums are also small bolt pattern. I bought a set just so I'd have spindles for my Viper caliper on 11.75" rotor upgrade. The spindles and rotors are mounted to my '72 Swinger. I still need caliper bolts, pads and pad retaining hardware.
I have Wilwood calipers and 11.75" rotors for my Valiant. Now that I think about it I'm just a pair of upper control arms away from having another late A-body disc brake setup.
