It is currently Thu Jun 18, 2026 3:04 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Sun Nov 23, 2008 8:37 pm
6 Pack Dart
Mark,
When did you hit 6100 rpm was it before the end or just ahead of the end?
You may have run out of your motor's power. Either way the 28" tires, should as Seymour said do you real good, without having to change the rear gears.
PostPosted: Sun Nov 23, 2008 8:39 pm
madmax/6 how did you get your car 2650 lbs with driver? The best I could get my car was 2650lbs with out driver and everthing cut out. Also another thing with the hp it never workes out close for me, my car is 2810 lbs with me in it and went 13.9 on the 1/4 at 93 mph but on the dyno it had 148 rear wheel hp
PostPosted: Mon Nov 24, 2008 3:45 pm
All lexan windows,no window regulators,plastic gas tank,no spare tire well,cut down bumpers and brackets,I weigh 185,mark
PostPosted: Mon Nov 24, 2008 5:58 pm
Is your car a street car or race only car ? i have all that done + lots lots more like alumum inner fenders, rad, rad suport trunk floor, firewall and floor pans also fiberglass fenders, hood, trunk , and race seats
PostPosted: Mon Nov 24, 2008 6:30 pm
It's a street car....
Although when I saw it, the headlights weren't working......
PostPosted: Mon Nov 24, 2008 8:24 pm
Street car,I drive it locally,not in the rain because I dont have wipers,,,remember this is a 62 Signet,,,the lightest car to start with,No fiberglass,,steel and some aluminum,seats are out of a Camaro,with padding and carpet,,,quite a few lightening holes,,and 40lbs worth of sub frame connectors,weight slip at the scales with 5 gal of gas was 2,466 ,add my 180lbs and you got 2,646
Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
