It is currently Fri Jun 12, 2026 8:32 pm
PostPosted: Sun Nov 23, 2008 12:56 pm
Which way does the distributor rotor turn in a slant six?
Also, what year did the electronic distributors start?
Jeff
PostPosted: Sun Nov 23, 2008 1:15 pm
Slant six distributors turn clockwise. Electronic ignition became standard in 73 (I think...)
PostPosted: Sun Nov 23, 2008 3:15 pm
Thanks! You wouldn't have a photo of what the advance mechanism looks like?
Jeff
PostPosted: Sun Nov 23, 2008 4:25 pm
Lots of vacuum pods on eBay to look at.
PostPosted: Sun Nov 23, 2008 4:39 pm
Hi, welcome on the board. Yep, 1973 was the first year for electronic ignition. First thing, soon as you can, go get the three books described and linked in this thread.
PostPosted: Sun Nov 23, 2008 4:54 pm
Mechanical advance mechanism:
Vacuum advance:
 Post subject: Err...
PostPosted: Sun Nov 23, 2008 5:41 pm
Reed's picture shows the weights and springs for a points distributor, without the 'governor'/limiter... the EI mechanism is similar, but has posts that are slightly adjustable for the advance springs, and you have a long looped primary spring instead of two full wound springs...
FYI, the EI vacc. can is a different beast than the points vacc can in how the armature is positioned.
-D.idiot
PostPosted: Mon Nov 24, 2008 3:52 am
Thanks a million! (You guys are great. THis is one super forum!)
Jeff
