It is currently Sat Nov 21, 2026 3:43 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Tue Nov 25, 2008 7:44 am
FYI...
I have always had trouble getting a carburator to work well with a turbo.
Think about when turbos on factory cars became more common... it was after they started using EFI with the them.
Doc, is that turbo/manifold setup in the pic from a buick turbo coupe?
PostPosted: Tue Nov 25, 2008 9:10 am
I run a blow thru Demon carb. Works really well after dialing it in. Don't people get more easy HP and drivability out of a blow-thru than a draw-thru?
You know it. All serious HP cars are blow-thru.
PostPosted: Tue Nov 25, 2008 11:33 am
Yes, I think it is off a 1985 Buick 3.8
The set-up as shown is on a bone stock 170 and would run mid 14 at about 12 lbs of boost... until it burns a piston.
I think I can get it to live with some additional tuning but the turbo 170 is no fun at the drag strip, no good off the line power... where everyone is watching.
The set-up does pull like hell as it get's on the turbo boost.
I never had a chance to hit the N2O but I bet that would help it come off the starting line better. (and cook pistons faster)
Users browsing this forum: Bing [Bot] and 6 guests
