It is currently Fri May 22, 2026 9:06 am
 Post subject: 8.25 Fill Plug.
PostPosted: Wed Nov 26, 2008 2:41 am
Well on my 8.25 the fill plug is always seeping a bit of fluid.. It has one of those Plastic / rubber type push in plugs - - not the thread in type. I have changes to a different plug and still the same problem.
It's impossible to have too much fluid as I have filled it with the correct amount and I has seeped so much for a while it as to be a few ounces under.
Thoughts to stop the leaking?
Should I try soaking the plug in the parts washer solution? I have done that be accident before and Made rubber stuff expand.
Thanks! Greg
PostPosted: Wed Nov 26, 2008 5:32 am
Greg, would it be possible to remove the cover, and either thread the hole to use a regular plug, or weld on a "bung" with threads?
PostPosted: Wed Nov 26, 2008 6:34 am
Does the 8.25 have a vent? I don't know diddly on most rearends just wondering if it's not vent properly and leaking out path of least resistance.
PostPosted: Wed Nov 26, 2008 11:05 am
I think the vent is integrated with the junction block for the brake lines. At least thats how it is on my 8 3/4" rear.
PostPosted: Wed Nov 26, 2008 1:25 pm
Yes this has a vent - Some have a vent like the 8.75's and some have a separate vent tube.. I should check it for blockage though.
Thanks, Greg
