It is currently Mon Jun 22, 2026 5:15 am
 Post subject: Carter BBD Jets
PostPosted: Mon Dec 01, 2008 3:56 pm
someone knows far more small jets for a carter bbd?
PostPosted: Mon Dec 01, 2008 4:21 pm
take a look at e-brock jets for their afb carbs.
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
PostPosted: Mon Dec 01, 2008 5:11 pm
There were 2 styles of BBd's Early and Late.. and you guessed it They have non interchangeable jets..
The early ones have versy small Jets and the later ones share the same Jets as Carter/Edelbrock AFb's / AVS's
The later BBd's Are Spotted With a Flat Tin piece Above the Fuel inlet to the carb.
PostPosted: Mon Dec 01, 2008 6:44 pm
Do the metering rods interchange?
PostPosted: Mon Dec 01, 2008 8:10 pm
Rug, If you mean from early to late..BBd's No..
If you mean AFb's to BBD's No there too.
PostPosted: Mon Dec 01, 2008 9:32 pm
But you can at least adjust the matering rods abit.
