It is currently Sun Nov 22, 2026 3:33 pm
 Post subject: exhaust manifold
PostPosted: Thu Dec 04, 2008 12:07 pm
I picked up a new exhaust manifold to replace the cracked one on my 62 225. It looks newer and stronger than the old unit. It also has a tube, a little larger than 5/16, sticking through the 3rd cylinder(from the front). What's it for and what do I do with it??
Thanks.
Joe
PostPosted: Thu Dec 04, 2008 1:35 pm
That almost sounds like a casting mistake but I’m not positive what you
mean. Any chance you can post a picture?
Do you see the same tube in any of these pictures?
Danny
PostPosted: Thu Dec 04, 2008 2:09 pm
Danny, I think it's your #4 photo that shows the 3rd cylinder with a boss on the top. Mine has a big flat spot with a hole through the top and bottom with a tube going all the way through and sticking out both ends about an inch. It's not the same metal as the manifold. I hope that makes it a little clearer.
I hate it when I know what I'm talking about and no one else does. I didn't even have a beer in my hand.
Also, when I get both manifolds off, I want to go with new bolts. Would they be a hardware store item or a parts store or MoPar?? Grade 8 or what??
Thanks.
Joe
PostPosted: Thu Dec 04, 2008 2:51 pm
That tube is used for an optional "carb de-icing" set-up, mostly used in cold weather areas.
There is some additional tubing and a special carburetor that is also part of that system.
PostPosted: Thu Dec 04, 2008 3:47 pm
OK, so what do I do with it?? Not worry about it, I'm using the old girl in the summer so deicing is not a problem.
Thanks.
Joe
PostPosted: Thu Dec 04, 2008 4:40 pm
That's an exhaust manifold used on all 1969 US-market and some 1960-1969 Canadian-market engines equipped with the carburetor anti-ice system (link contains details), and 1967-1975 export engines with the integral-choke 2bbl carburetor. You may safely ignore it if you're not using it.
PostPosted: Fri Dec 05, 2008 2:58 am
PostPosted: Fri Dec 05, 2008 3:05 am
Another wealth of information. Thanks. I've already got my Remflex gasket but that was the only thing that I had planned ahead on. The guys at NAPA smile and rub their hands together when they see me come through the door.
Thanks again.
Joe
Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
