It is currently Fri Jul 17, 2026 2:06 pm
 Post subject: Black crinkle paint
PostPosted: Thu Dec 04, 2008 6:30 pm
Can anyone recommend a good brand of crinkle finish paint? I want to do my valve cover. Also, any tips on application? I've never used the stuff before.
Thanks in advance,
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Thu Dec 04, 2008 8:41 pm
VHT make a very good black, grey, or red wrinkle finish in spray cans. Application is pretty much like other paints: paint warm but not hot, parts clean-clean-clean and warm but not hot, multiple coats, keep the can moving, etc.
PostPosted: Thu Dec 04, 2008 11:05 pm
Thank you sir!
PostPosted: Fri Dec 05, 2008 3:39 am
Read the directions on the can and follow them to the T. It's been a while since I've used wrinkle finish paint but as I recall you lay down the first coat and let it dry for a specified time then apply the second coat. The second coat shrinks when it dries to produce the wrinkle finish.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Dec 08, 2008 11:10 am
I put down a layer of Krylon black primer and then heavy wet coats (per instructions) of Krylon black wrinkle paint; it worked quite well and has lasted for years on my air cleaner. Generally, I've been very pleased with the durability of Krylon and far less so with some other brands.
