It is currently Fri Dec 26, 2025 12:19 pm
Post new topic  Reply to topic  [ 37 posts ]  Go to page 1 2 3 Next
PostPosted: Fri Dec 05, 2008 5:14 pm
We are shooting for the low sixes or maybe high fives with our turbo nitrous injected slant six Duster
PostPosted: Fri Dec 05, 2008 6:16 pm
post pics when you can james, i will be interested to see what you come up with.
PostPosted: Fri Dec 05, 2008 7:13 pm
1/8 th mile track,with a 3.000 lbs car WITH driver would need how much Hp to get into the 5s,My gut feeling is that its going to be very hard to do,mark
PostPosted: Fri Dec 05, 2008 7:28 pm
The biggest issue will be getting the head gasket to stay in when you hose it under boost. :shock:
I thought they were going to get lighter than 3K? :?
PostPosted: Fri Dec 05, 2008 8:06 pm
OK. thanks for the info James :roll:
I'm shooting for the 4's so there! :wink: (but that is a 100' mark!, you should see my 60' mark 8) )
Chris'
Autobody
Restoration
Service
PostPosted: Fri Dec 05, 2008 9:24 pm
3,000,with a driver was a guesstamate on a Duster,on my part,,,,,computer literate people.answer my question,,,,,how much hp is needed to get a 3,000 lbs car into the 5,s?curious,mark
PostPosted: Fri Dec 05, 2008 9:42 pm
ala dragsim
with on of my imaginary monster slants
1200Hp @7500
800lbft @5500
gives 5.482 1/8th mile in duster with all the highstall drag racing slick stuff
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Sat Dec 06, 2008 4:09 am
My ET/HP calculator says 723 hp for a 6.0 et in the 1/8 at a 3,000 car weight
PostPosted: Sat Dec 06, 2008 6:26 am
Thats all???? Could get that for a pass or two :lol:
If you think about it, Top Fuelers rebuild and replace most of their engines after every run. And some of them don't make it to the 1/8 mile mark before blowing. So, with unlimited funds and parts a guy could run some insane times eventually. You just need it to hold together for 660 feet :roll:
Chris'
Autobody
Restoration
Service
PostPosted: Sat Dec 06, 2008 6:51 am
Didnt ask you what kind of rearend ratio and what tranny would you be using - also - hog high above sealevel, and what tirewidth - I plumbed in my own stuff lemme know oh yes and the stall speed of your converter - are you an agrssive drive or pro - sorry that is the inputs this thing is asking :D :D
Regards,
Fanie Gerber
PostPosted: Sat Dec 06, 2008 3:02 pm
I saw the Simca make a 6.10 run at Farmington in about 2006, but that car is around 2400 racewt.
PostPosted: Sat Dec 06, 2008 4:53 pm
Mike went 6:15 once @ 2675#. :shock:
 Post subject: # of passes
PostPosted: Tue Dec 09, 2008 6:43 am
That is the biggest factor. I did'nt say how many passes I was going to make. There is no doubt I will destroy the engine trying to do it, but I am one of those guys. That is the big thing in street racing. The poor guys throw a cam in a stock engine that make 195 hp and then spray it with a 500 shot of nos. I have seen them win a lot of money like that. I have also seen them change engines three or four times in one week. Oh. By the way 1,200 hp would put you in the low to mid eights in a quarter mile in a 3,000 lb. car.
PostPosted: Thu Dec 11, 2008 6:02 am
My calculator says 650hp @3000Lbs. I thought the Duster weighed close to 2800Lbs stock so I don't think you'r too far off on weight. My coworker says that at the local delkperformance shop the Mustang guys are stroking their v6 with the the f150 4.2 cranks and making close to 650 with turbo and close to the numbers your looking for. Hey, if a v6 Mustang can do it anyone can, right?
________
herbalaire vaporizer
 Post subject: Re: # of passes
PostPosted: Thu Dec 11, 2008 9:41 am
:shock: :) :!: I like the cut of your jib.
Users browsing this forum: Google [Bot], Rick Covalt and 16 guests
