It is currently Tue Nov 24, 2026 10:16 am
 Post subject: HEI upgrade.
PostPosted: Sun Dec 14, 2008 9:55 am
Ok,I know you all must be sick of my questions by now,but I need one more.The points in my 67 HAVE to go! I want to do the HEI upgrade.My only problem is that I dont like the looks of most of the installs I have seen(no offence to anyone :!: ) I have always been a function over form guy,but I dont want a bunch of multi-colored wires sticking out.Does anyone have a really clean install of the HEI? I want mine to look as stock as it can for new gm parts in a old Mopar!This car means a lot to me so I want to keep it looking clean under the hood.
The only reason I am considering the stock system,is for how clean and stock you can make it look.So does anyone have any pictures of their install? I tried to do a search for is but it keeps comming up with an error when I try to search.Am I doing something wrong?
PostPosted: Sun Dec 14, 2008 1:58 pm
The cleanest installation would probably come from using the combined coil/module/bracket assembly as shown in the HEI upgrade article. You can get the factory wiring connector plugs out of the wrecking yard, and use convoluted wire loom to create a tidy wiring harness.
PostPosted: Sun Dec 14, 2008 2:13 pm
Do you have pictures of your install SSD? I would definatly use the GM coil and bracket combo if I go this route!
PostPosted: Sun Dec 14, 2008 3:09 pm
No pics...last HEI installation I did was on a car I no longer own, and I spend more time on here than under the hood lately, so my '71 still has points. :-( :roll:
PostPosted: Sun Dec 14, 2008 4:34 pm
Gotta get those pesky points out of there Dan! I was hoping someone had some pictures of a clean install,I really am not much of an electrician.I know if I just try and do it myself,it will look like crap.But if somone had some pics and a description of a clean install,I might do ok to follow it...
PostPosted: Sun Dec 14, 2008 5:29 pm
My $40 HEI writeup has a picture of the coil and module assembly I used.
http://slantsix.org/forum/viewtopic.php?p=186912
