It is currently Wed Nov 25, 2026 3:45 pm
 Post subject: harmonic ballancers
PostPosted: Mon Dec 15, 2008 3:15 am
Hi Guys
Question here - are all slant six harmonic balancers interchangeable? - I am not talking about timing marks, but mechanically
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Mon Dec 15, 2008 3:23 am
Yes. The cast crank ones will work on a steel crank motor too. The main differences are the location of the timing marks and the number of spokes, but they will all interchange physically. :D
PostPosted: Mon Dec 15, 2008 3:31 am
Answer I was hoping for just bought a balancer NOS mopar spoked hub for 29USD :D
Regards,
Fanie Gerber
 Post subject: e bay
PostPosted: Mon Dec 15, 2008 7:33 am
e bay can be your friend! 8)
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Mon Dec 15, 2008 2:33 pm
Good deal! :D
PostPosted: Mon Dec 15, 2008 11:14 pm
I came across an NOS one on ebay before and thought of buying it just to stock up. But then I thought to myself, how much do I trust x decade year old rubber parts?
PostPosted: Mon Dec 15, 2008 11:20 pm
True. I bought a Power Bond as an upgrade. I plan on spinning my 198 about 6500 RPM so I thought it a wise investment.
PostPosted: Tue Dec 16, 2008 6:39 am
At what stage did they start using spoked units? - we only ever had the solid hub type over here :?
Regards,
Fanie Gerber
PostPosted: Wed Dec 17, 2008 8:23 am
I bought a couple of those NOS $29 units from Kiwijohn on ebay recently. They look in perfect shape and are a bit lighter than the forged crank units, likely due to cast crank application? Maybe just the hub is lighter.
So far, I have never had a balancer fail on me, except for 20 yrs ago beating on one with a hammer and cracking it through the keyway (my fault).
PostPosted: Sat Dec 20, 2008 7:30 pm
I need to remove one. How do they come off? There doesn't appear to be bolt on the thing!
PostPosted: Sat Dec 20, 2008 7:59 pm
The best way is to use a harmonic balancer puller, like this one sold at Sears for $20.
PostPosted: Sat Dec 20, 2008 8:20 pm
Most don't have a bolt in the crank from the factory. They are press on/interference fit. You need a puller like Reed showed.
PostPosted: Sat Dec 20, 2008 8:27 pm
much appreciated.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 7 guests
