It is currently Tue Nov 24, 2026 11:40 pm
 Post subject: heads intechangable?
PostPosted: Tue Dec 16, 2008 6:10 pm
I have a 170cid with a bad head.Can I use the head from one of my 225cid in it's place? :idea:
PostPosted: Tue Dec 16, 2008 6:14 pm
Site Admin
As long as it's a mechanical top end you can.
CJ
PostPosted: Tue Dec 16, 2008 6:22 pm
Actually, all slant six heads interchange, so long as you use the rocker arm assembly and hardware for the specific head-style. Hydraulic heads will bolt to non-hydraulic blocks, but you have to use the rear-most bolt from the hydraulic rocker shaft in the hydraulic head. All heads interchange between 170, 198, and 225 blocks.
 Post subject: reply
PostPosted: Tue Dec 16, 2008 6:57 pm
Thanks guys for the info. Now the only thing standing in the way of me having a running valiant is the torque specs
PostPosted: Tue Dec 16, 2008 8:35 pm
Sixty five ft-lbs for the head bolts, 25 ft-lbs for the rocker arm, and 10-12 ft-lbs for the manifold set to head. I ran a hydraulic head on my '73 engine, and had to swap the rocker arm and rockers from the '73 head to the '82 hydro head, using the rear bolt from the '82 head with the rocker arm.
PostPosted: Wed Dec 17, 2008 3:32 am
Hydro head takes it's own valve cover and gasket too. :D
