It is currently Wed Sep 16, 2026 6:06 pm
PostPosted: Sun Dec 21, 2008 12:37 pm
edit: I have a website now: www.tbiadapterplates.com
I'm a CNC machinist and I made an adapter plate to put a GM TBI throttle body onto a Carter BBD 2BBL intake manifold. I had Jeeps in mind when I machined the plate, but it has recently come to my attention that some Slant 6's also used the Carter BBD. This plate fits on a Jeep/AMC 258, does anybody know if I need to make any changes/clearances for a Slant 6?
Last edited by Chris in Idaho on Mon Feb 09, 2009 9:00 am, edited 1 time in total.
PostPosted: Sun Dec 21, 2008 12:48 pm
Interesting piece. If it fits the Jeep BBD mounting pad, it'll fit the Slant-6 2-barrel mounting pad (and the Mopar 273/313/318 2-barrel mounting pad, for that matter). The GM TB is a much better pick than the Holley junk Chrysler put on the 3.9, 5.2, and 5.9 in trucks from '88-'91.
(Shutterfly isn't an image-hosting service, it's a print-selling business, and can't be used to host images for remote presentation such as on the board here.)
PostPosted: Sun Dec 21, 2008 5:03 pm
Car Model: 62 Lancer, 63 D100
Let's have more on this topic.
PostPosted: Sun Dec 21, 2008 5:34 pm
I am also interested in this. Would the GM throtle body injection be triggerable by an HEI unit?
PostPosted: Sun Dec 21, 2008 5:49 pm
Here's a wealth of information about running GM TBI on a slant 6:
http://www.rowand.net/Shop/Tech/SlantSixTBISwap.htm
PostPosted: Sun Dec 21, 2008 6:00 pm
Imageclick to view full-version
PostPosted: Sun Dec 21, 2008 6:18 pm
That's a really interesting page. Too bad for the people at Howell that they took such delight in being such jerks about their adaptor plate. Perhaps if they hadn't, then Chris in Idaho wouldn't have had to go to the trouble. I'm tempted to buy one of these adaptor plates even though I don't have any current plans for a TBI swap, just for that reason alone.
PostPosted: Sun Dec 21, 2008 6:32 pm
I might be interested in one of these in the furture. I am interested in terofitting reliable EFI to a hydraulic slant to sort of build a injected hydraulic "modern" slant that Chrysler never did. I know TBI is inferior to MPFI or even BFEFI, but it is an interesting first step.
PostPosted: Sun Dec 21, 2008 7:04 pm
If anybody's interested, I listed a plate on ebay. It's item number 260335350418. I'm very new to this forum, so if I'm breaking any rules by advertising my own stuff for sale please let me know.
PostPosted: Sun Dec 21, 2008 7:07 pm
You didn't break a rule — welcome on the board, by the way! — but you may want to post an ad here on the board in the "Parts For Sale" section. An actual price (I send you such-and-such an amount of money, you send me adaptor plate) would probably make you more friends than a pointer to an eBay auction.
PostPosted: Sun Dec 21, 2008 7:39 pm
Thanks for the advice, I'll go ahead and post in the for sale section.
PostPosted: Mon Dec 22, 2008 10:46 am
Looks very cool. One trick to using GM EFI electronics on a slant six is that if you are using a computer controlled ignition you can drop in a Lean Burn distributor and wire it up to a computer controlled HEI module. I did that on my Dart.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Mon Dec 22, 2008 4:59 pm
7 pin modules are the jewel in the GM TBI system....they just need a real ECU to work with.
PostPosted: Thu Dec 25, 2008 11:05 pm
You don't need the 7 pin HEI if you are using a Megasquirt II. The lean burn distributor should be able to trigger the megasquirt directly.
There is a lot of offset on the throttle bores for a tbi to bbd adapter. Close to 1/2" if I remember correctly. Makes me think of a 2v to 1v adapter. I would think, making an adapter plate for the offy manifold would be a better investment.
If you want MPEFI, the tbi body, without the injectors and regulator would make a very nice 2v throttle body. You could then also use a standard after market air cleaner with the Holley (5") opening.
PostPosted: Fri Dec 26, 2008 9:51 am
There's offset, but from these pictures it's nowhere near as severe as with a 2bbl to 1bbl restrictor, er, adapter. You know I'd never use a 2bbl-1bbl "adapter" because they're dumb, but I wouldn't have any qualms using this adaptor as pictured.
