It is currently Thu Nov 26, 2026 5:50 pm
 Post subject: Weird Occurrence
PostPosted: Fri Dec 26, 2008 10:34 am
i was driving down the road yesterday and my car made this loud backfire [right now i have no muffler and it was freezing outside] and my car jerked forward and shut off so i pulled onto a off ramp and checked my oil and for holes in the block and any leaking and couldn't find anything out of the ordinary. so i started it back up it started just fine and i drove about 10 feet and the car jerked forward again and then smoke started coming up from the hood [not the front of the hood the sides] and a cop pushed me to a parking lot and i tried starting it again and it made no sound at all when i turned the key not even the starter.
225 Slant Six [Super Six]
PostPosted: Fri Dec 26, 2008 11:03 am
Sounds electrical. Could you be more specific as to where the smoke came from (fire wall, wires along engine, near battery)? What year is your car?
PostPosted: Fri Dec 26, 2008 4:31 pm
I've got a 1970 Plymouth valiant and the smoke looked to be coming from the fire wall and the smoke smelled rubbery
PostPosted: Fri Dec 26, 2008 10:14 pm
i think it might be my fusible wire its split and that's about where the smoke was coming from what should do?
PostPosted: Fri Dec 26, 2008 11:08 pm
Replace the fusible link and find out why it shorted.
Fix the overload or short and then replace the fusible link.
PostPosted: Sat Dec 27, 2008 8:07 am
Until you track down the cause of theblown fusible link, you may want to install a temporary circuit breaker instead of another fusible link.
