It is currently Fri May 15, 2026 10:27 am
 Post subject: Converters
PostPosted: Wed Mar 12, 2003 1:15 pm
SSRN National Champion
THE PERSON BUILDING MY ENGINE WANTS ME TO BUY A BILLET TOURQUE CONVERTER. ALL MY BUDDIES RUN CONVERTERS FROM PTC. I DON'T KNOW WHAT TO DO.
PostPosted: Wed Mar 12, 2003 2:20 pm
Norm,
There are many good and many bad TC companies out there. I (and Doug) have had good experience with Continental Converters in Inglewood, CA. Dennis has had good experience with Midwest Converters (don't know where - check links section?). TCI and Turbo Action have good reps. The most important thing is to get the right stall rating. Typically a converter rated for a V8 will stall about 30-40% lower on a Slant. Also, make sure to get the alloy pump drive hub on whatever you buy.
Now I bet you're really up in the air...
PostPosted: Wed Mar 12, 2003 7:01 pm
Midwest Torque Converter, Rockford, IL. 815-229-9808 They will build you one that does what you want it to do. :shock:
PostPosted: Thu Mar 13, 2003 7:08 am
It helps if the converter company has built for slant six motors before. It gives them input at how to set the converter to give the stall speed wanted. Most converter companies will adjust your converter at no charge if they miss on the desired stall speed, but, I don't want to pull it out once it's in so I'd buy from someone who's done a few for the slant six.
BTW Norm, is the billet converter you mentioned the name of the company making them or a type of converter?
Cecil
