It is currently Mon Nov 16, 2026 8:56 pm
 Post subject: Will It Fit
PostPosted: Thu Jan 01, 2009 11:53 am
Would anyone know if a 1980 727 Torqueflight from a /6 would bolt up to a 65 273? Same bolt pattern?
PostPosted: Thu Jan 01, 2009 11:57 am
Nope, not even close.
PostPosted: Thu Jan 01, 2009 1:27 pm
Well, dang it anyway. Had a buddy with an unused 273 I thought I might swap into the ol truck while I worked on the /6. Maybe I can find an auto to go behind the 273. ......Thanks much!!!
PostPosted: Thu Jan 01, 2009 1:30 pm
You'd need a '66 transmission for that swap. '65 won't hook up to your truck's shift or kickdown linkages or driveshaft, and '67 won't fit behind a '65 engine. (the small-large torque converter nose change was one year earlier for V8s than for slant-6s, if I recall correctly).
PostPosted: Thu Jan 01, 2009 3:06 pm
I would never endeavor to bet against your recollection Dan, I'll take a look at the "parts for sale" tab. Thx again.
PostPosted: Thu Jan 01, 2009 4:58 pm
SSRN National Champion
Well I would bet against Dan but not on this issue he is Dan right. Thanks Ron Parker :D
Do You Feel Lucky Dan Well Do You Coffee Lover
PostPosted: Thu Jan 01, 2009 7:12 pm
I like that one Ron,Dan straight he's Dan right :lol:
