It is currently Sat Jun 06, 2026 3:36 am
 Post subject: Rocker arm clearance
PostPosted: Thu Jan 01, 2009 3:28 pm
1982 Dodge truck, slant 6, 4 speed manual, 2bbl carb.
Quick question, there should be some clearance between the rocker arms and end of the valve stems, correct? I can't seem to get a feeler gauge in there and none of the rocker arms will even wiggle the tiniest bit by hand. If I'm reading my factory service manual correctly, I should be able to get at least an 0.060" gauge in there and I can't.
If I am reading this all correctly, how do I go about fixing it? Shims under the rocker arm shaft? Grind down the valve stems? Thicker head gasket? New push rods?
John
PostPosted: Thu Jan 01, 2009 3:37 pm
If it is the original motor, it should not need adjustment because it is a hydro motor.
PostPosted: Thu Jan 01, 2009 3:40 pm
It is the original motor as far as I know. Had it rebuilt a while back - short block only to help save some cash. I know there's no adjustments in the rockers, just thought there should be some clearance there.
PostPosted: Thu Jan 01, 2009 3:53 pm
Hyd lifters are 0 lash so unless someting is wrong shouldn't be any gap.Thats all subject to change with deck'd block,shaved head,bum lifters etc.
PostPosted: Thu Jan 01, 2009 3:58 pm
Which is exactly why shaving the head/block is a pain for those with the hydro setup. If the lifters aren't allowed the right amount of movement, say good bye to some internals.
~THOR~
PostPosted: Thu Jan 01, 2009 5:59 pm
OK. Thanks for the info. My FSM is NOT really clear about that.
Now to figure out why I have to set my ignition timing at around 25 BTC to get it to run. The guy who rebuild and assembled short block might not have degreed the cam properly. I dunno. I guess I'll have to take the truck to him and see what he thinks. Right now only getting around 12-13 mpg out of it and I know it should do better.
PostPosted: Thu Jan 01, 2009 6:58 pm
25 BTDC? Sounds like he didn't even connect the dots let alone degree the cam :shock: Man thats a wack load of B4s,you sure on that?
PostPosted: Thu Jan 01, 2009 7:15 pm
That's what I thought, although the engine seems to run OK, just uses a lot more gas than I think it should. Heck, I know I can get way better MPG with a 318/727 combo as I got better than that with a 4WD Ramcharger.
I've got one of those timing lights with the adjustable timing and I have to crank it around to 22-25 BTC to get the timing marks to line up.
Could the marks on the crank pulley be that far off?
PostPosted: Thu Jan 01, 2009 7:44 pm
Ring on the balancer could've slipped.
Rob M
'80 D100 SWB stepside, S6 4-spd OD
