It is currently Fri Nov 27, 2026 11:44 pm
PostPosted: Thu Jan 01, 2009 9:01 am
My pour old 63 Valiant finally started to smoke I have found a 46.000 mile 225 engine out of probally 78-79 dodge truck. Can I put this into my car I have anouther oil pan from a passenger car to change over for that so what else would I have to cjange to get it in there?
PS the truck has elctronic ignetion
PostPosted: Thu Jan 01, 2009 9:17 am
You would need the oil pickup tube, and what transmission do you have?
PostPosted: Thu Jan 01, 2009 9:22 am
The electronic ignition would be a nice upgrade, as would the dual field alternator.
You will need to use the oil pan, oil pickup, and motor mounts from the 63 engine. If you have an automatic transmission, you will need to use the adapter/spacer ring for the crankshaft snout due to the 68 and up crankshaft having a larger bore for the torque converter.
PostPosted: Fri Jan 02, 2009 10:42 am
Also the flex plate that goes with the big hub crank.
PM me if you need the adaptor ring and/or a big hub flex plate.
PostPosted: Sun Jan 04, 2009 10:03 pm
I performed that swap; I put a '83 Dodge pickup engine in a '63 Valiant. A little trouble, but a good swap. Runs like a scalded dog and gets ~25 mpg. One thing though, the truck engine might have a 2-bbl carb in which case you need to change the exhaust to 2-1/4" to adequately accomodate the additional air flow. Also, you might need to change the oil dip stick to the small one used in '63. There is a little plug in the block of the later model engines that you can knock out and install the short dip stick tube. I changed the torque converter to one with the larger nose for the later crank that also fit the '63 transmission. It seems there are converters built now for that very application. Just a thought as an option to the spacer Doug mentioned. I have used both methods and either seems to work well. Good luck on the conversion. Regards. RMDV
Carl Zeamer. an old guy, please be gentle.
PostPosted: Mon Jan 05, 2009 5:43 am
No, you don't need to. It's certainly a good upgrade, but nothing bad happens if you don't do it immediately.
That's a custom-built torque converter, not an off-the-shelf piece.
 Post subject: Re..truck to '63 Valiant
PostPosted: Mon Jan 05, 2009 10:11 am
Dan,
Agreed the torque converter is not a "stock" item, but the distributor had six in-stock on the shelf when I had my trans re-built. It seems the demand for that type convertor has made it economical for some jobbers to carry the "converted" convertor, if you will.
Yes the truck engine will run with the stock '63 exhaust, but if it is equiped with a two barrel carb it won't be as efficient. The stock '63 Valiant exhaust is about 1-3/4 to 1-7/8" dia and was designed to accomodate a single brrel carb; at least the two I have are/were that way. If the replacement engine is using a two barrel then the exhaust should be changed to achieve max efficiency due to the increased air flow at higher engine speeds. Regards. RMDV
Users browsing this forum: Ahrefs [Bot] and 6 guests
