It is currently Wed Apr 29, 2026 3:14 am
 Post subject: Slant six rocker arms
PostPosted: Thu Jan 01, 2009 7:24 pm
I installed a set of super six rocker arm shafts on a regular 225 motor - is the oil bolt the same? I want to make sure to get enough oil.
PostPosted: Fri Jan 02, 2009 1:54 pm
AFAIK, the "Super 6" arms are no different than any other motor unless you used a set of hydraulic arms.
However, the later model shafts do use a stepped bolt in the back hole. If your 3/8" bolt went through the shaft you are good.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
